Jon Dugan
Jan 3 2016, 02:17 AM
Hello fellow 914ers,
First post here... My 74 2.0 was my daily driver for the past 5 years until it decided not to be... Ran fine one night, parked it, next morning no so much. Starts right up no problem but rev above say 2000 RPM, it wants to bog out and stall. I do get an occasional smooth rev through to red line though. Tried advance/retard adj with the dist and can now only find idle around 1600 RPM (normal idle was about 600 RPM I think) but then lose it whwn I try to dial it back down. Dist checks out fine ($65 test by Porsche mech in Campbell). The guys at PH suggest maybe the fuel pressure sensor (grenade) has failed. I have limited troubleshooting skills and budget and was hoping to get back into AX this year after a long hiatus so any suggestions will be much appreciated. Thanks in advance !!
ndfrigi
Jan 3 2016, 03:18 AM
I'm sure members here will ask this, FI or Carb? If FI maybe vacuum leak.
JeffBowlsby
Jan 3 2016, 07:34 AM
Does it run rich or lean or just bog down?
Check the MPS to verify of it hold vacuum. 15 inHg.
Lube the dizzy weights by 1 drop of 30wt in the felt in the center of the dizzy shaft, annually.
Jon Dugan
Jan 3 2016, 09:38 AM
FI
It has run rich since I bought it. Run well too... I'll check the MPS and lube the felt next as suggested. Thx!
Jason74914
Jan 9 2016, 09:35 AM
I have same issue with my 74. Will start and idle, but if you pull rpm's up, at about 2000 rpm it stalls back down to idle. (doesn't die). If I rev quickly it will go above 2000, but then fall back down.
I've checked everything. Checked pressure and seems good at idle, 40 psi. Someone else suggested a bad fuel pump, but seems odd since pressure is good. Fuel pressure regulator? I'm not sure how to test that.
Jason74914
Jan 9 2016, 09:36 AM
Jeff, What are you referring to as MPS?
JeffBowlsby
Jan 9 2016, 10:18 AM
Manifold Pressure Sensor
What 'pressure' are you checking to get 40psi?
Jason74914
Jan 9 2016, 10:33 AM
QUOTE(Jeff Bowlsby @ Jan 9 2016, 10:18 AM)
It was several months ago, but I think it was just before the fuel pressure regulator/fuel rail.
Jason74914
Jan 9 2016, 10:43 AM
QUOTE(Jason74914 @ Jan 9 2016, 10:33 AM)
No wonder I didn't recognize the MPS...I have 1.8L with K-Jet.
TheCabinetmaker
Jan 9 2016, 10:50 AM
Kjet? 1.8s came with Ljet.
I had to read this thread twice to figure out Jeff was talking to 2 different posters. Lol.
JeffBowlsby
Jan 9 2016, 10:53 AM
Assuming your car is a stock 1.8L L-Jet, fuel pressure should be 32-38 psi. 40psi is too high.
This manual may be helpful to you:
http://bowlsby.net/914/Classic/zTN_Man12.pdf
Jason74914
Jan 9 2016, 05:08 PM
QUOTE(Jeff Bowlsby @ Jan 9 2016, 10:53 AM)
http://bowlsby.net/914/Classic/zTN_Man12.pdfSorry, yes L-Jet (typo). I will re-check, but thanks for the link!
achman_73_2.0
Jan 9 2016, 08:58 PM
I chased a similar issue for a year with my 2.0 FI '73
Turned out to be a small leak in intake manifold
Caused engine to run lean under load, and with a high idle to prevent stalling...
I would check that before the MPS (I wish I had!)
It's a cheaper fix than getting that rebuilt etc.
Jon Dugan
Mar 19 2016, 10:44 AM
Back for more suggestions... Just replaced the MAP with a New/Rebuilt one... Car started fine and idled @ 1800 rpm or so, lower than before, but still can't dial it in.. It still intermittently revs smoothly for a few revs then reverts back to a flutter rev @ 2000 RPM and above. Both at the same distributor position. I spent about an hour advancing/retarding the timing with the distributor and found a sweet spot for a smooth rev through to about 5000 RPM, but as soon as I tightened the distributor in that position, the flutter rev returned...Argh! Hoping one of you guys can offer any other troubleshooting suggestions and/or recommend a mechanic preferably in the Hayward area with good 914 experience that I could tow to and not be taken to the cleaners so-to-speak.... Thanks in advance !!!!
Jeffs9146
Mar 19 2016, 12:38 PM
Have you checked the Aux Air Regulator or the CHTS?
Jon Dugan
Mar 19 2016, 12:56 PM
QUOTE(Jeffs9146 @ Mar 19 2016, 11:38 AM)
Jeff, thanks for responding... What is CHTS? My abbreviation knowledge needs some work
Jeffs9146
Mar 19 2016, 12:58 PM
QUOTE(Jon Dugan @ Mar 19 2016, 10:56 AM)
Cylinder Head Temp Sensor
Also Vacuum leaks are very bad!
Jon Dugan
Mar 19 2016, 01:10 PM
QUOTE(Jeffs9146 @ Mar 19 2016, 11:58 AM)
Makes perfect sense... Thanks for the suggestions !!! It's looking like I can use all the help I can get.. 5+ years as a daily driver with no real problems was too good to be true...
TheCabinetmaker
Mar 19 2016, 01:39 PM
No dwell adjustment in 5 years? I'm gonna assume that valves haven't been adjusted either. I'd do both. You can set the timing all day but if dwell is off it doesn't do any good. Valves first, then dwell, then timing. I'm betting your points are closed. Pop the diz cap, put the car in 5th gear, roll car forward till points rub block set on one of the 4 high points on the diz shaft, then set it to .017 (17 thousandths) clearance. Then check dwell and reset the points as many times as it takes to get the dwell to 47 degrees + or - 3 degrees.
Jon Dugan
Mar 19 2016, 02:22 PM
QUOTE(The Cabinetmaker @ Mar 19 2016, 12:39 PM)
Thanks for the response!! I did have a valve adjustment/tune-up about 4 years ago so I'm no doubt overdue. I also went will optical in the diz.. I've been hoping to get it running well enough with a possible "obvious" fix per the symptoms, to drive it, rather than tow it, the 40 miles to the mechanic that did the work last time.... Good Times !!
