80cap
Jan 3 2016, 09:46 AM
I just reinstalled my head light assemblies. I have not yet installed the wiring.
How do you sync the system one I wire up the motors. I can't find a thread on this
subject.
Thanks Brian
Catorse
Jan 3 2016, 10:28 AM
QUOTE(80cap @ Jan 3 2016, 07:46 AM)
subject.
Thanks Brian
I've never heard of such a procedure and I have 2 cars with popup headlights - 944 and 914. I will make sure the switch is in the off position, then reinstall the headlights. The I use the knob on the back of the motor to manually wind them down and closed.
Start the car, flick the lights on a couple times, and they are good to go.
Garland
Jan 3 2016, 11:21 AM
Disconnect the arm from the motor to the headlamp assembly at the motor. Power up the motors by the headlamp switch, on, then off. The motors are now parked in the closed position. Reattach the arm to the motor, with the headlamp door down/closed.
80cap
Jan 3 2016, 12:50 PM
Thanks
Brian
toolguy
Jan 3 2016, 01:51 PM
This is a very abbreviated description of the steps and process. .
If you disturbed the headlight pivot's mounting allens, it's a lot more difficult. . You'll need to align each door to be parallel and perpendicular to the hood and fender and eyebrow. . This is done by rotating the headlight pivot shafts. Not oly are you adjusting the gaps , but you're setting the height to match the hood level.
First, remove the headlight motor actuator relay by the motor. . this is so you don't mash fingers. .
Also be aware there is an full open door stop adjustment which keeps the headlights from wiggling when open and driving. . it's the big long bolt at the rear of the headlight bucket with the set nut. this is the last thing to adjust. Before you reassemble the door, inspect the top stop bolt and how it braces the headlight base when fully raised. This way you'll understand the very last adjustment, the door stop bolt.
Disconnect the raise lower arm from the motor / 10mm nut on bevel shaft.
gently pry the arm loose on the serrated bevel so the door will go up and down manually.
with the arm lose, adjust the headlight door with the inner and outer pivot mounts so the door is properly aligned. It can be a bitch to get perfect. All this does is align the door. Tighten the pivot allens when gaps are set.
Next is to get the full open and full closed position in place. If you haven't rotated the black knob on the rear of the motor, the motor is still in the 'full down position.
Connect the actuator arm back on the motor shaft in the furthermost down position. . The door will probably be too high or too low. . Now the height is adjusted by loosening the 3 motor mount allens and repositioning the motor. Now the full down position is set. If the arm is not in the fully down position, this is why some headlights start the up cycle by actually going down a little then up. .
Next to the full up position and the door stop bolt adjustment.
With the relay still removed, rotate the black knob on the motor until the door is raising itself to full up. . you need to feel as the door rises to contact the stop bolt.
You want to adjust the bolt in or out so the door mount assemble barely contacts the bolt in the fully raise position. . too tight and it binds the headlight motor operation. . too lose and the headlights will wiggle and vibrate when driving. .
Don't be surprised if it takes all day to do both sides if you want it perfect. .
whitetwinturbo
Jan 3 2016, 03:37 PM
I'm missing one of the black knobs on the rear of the motor. One side has it and the other side is gone
Where do I find another one?
boxsterfan
Jan 3 2016, 10:15 PM
QUOTE(whitetwinturbo @ Jan 3 2016, 01:37 PM)
Probably just find a used one here in the classifieds. Place a WTB ad.
shoguneagle
Jan 4 2016, 10:05 AM
As always information comes out regarding areas I am working on my car. Rebuilding the headlight assemblies and just about completed; what do I need? Adjustment of headlight movement? Do I need it?
Along comes this thread; could have been timed better.
Thanks!
Mikey914
Jan 4 2016, 10:49 AM
All the adjustment for the lights is on the outside arm. Simple as that.
Just make sure to remove the relay when the lights are up, and adjust from there.
