72wrxporsche914
Jan 3 2016, 09:47 PM
Removed the master cylinder and wanted to replace the plastic feeder lines . Are they still available I've looked everywhere .
boxsterfan
Jan 3 2016, 09:50 PM
QUOTE(72wrxporsche914 @ Jan 3 2016, 07:47 PM)
pmbperformance.com has them
http://www.pmbperformance.com/catalog/item...63/10069609.htm
72wrxporsche914
Jan 3 2016, 10:55 PM
Thank you just ordered two sets .
SKL1
Jan 3 2016, 11:05 PM
I'm using the ones from Eric, and they work but are not "preformed" or have the bends in them like the OEM ones. Not sure if the shape is just from them being in that position for so long, or if new ones (if you could find them) actually have a liitle shape to them.
All I do know is they are a major PITA to replace, especially with the gas tank in place...
Series9
Jan 4 2016, 08:44 AM
If it doesn't have to be original, I have recently had success using a fuel nipple that's the correct size to push the "mushroom" end of the nipple into the grommets on the master cylinder.
Once you do that, just run blue, braided brake supply hose between the MC and the reservoir.
In the attached picture, just the piece in the middle. It's the size for the fuel rail return line connection on a CIS /6 or Motronic 3.2.
