Hopefully someone could hepl me....
Where is the promblem ??
When I start my 3.0L six, it blows big smoke cloud. Yesterday I opened the right side valve cover. There came out about 3 liter oil Before that the engine had been not running about 6 days.
Is it so, that the oil pump let the oil drain from the tank to the oilpan ?? Is there somewhere some kind of back-pressure valve, or should the toleraces in the oil pump be so tight, that no oil can go through it?? Should the oil pump be fluid-tight when the engine doesnt run ???
Or, is it normal that you find your oils in the engine after couple of days ?? How is it ?? Any experiences ?? Any advices ??
Should I chance new valve steams ?? Or pistons and cylinders...
