QUOTE(Gearup @ Jan 4 2016, 09:17 AM)
Thanks Guys. I would love one of Mark's but it seems with his production and the fact that I am tail end Charlie on the extensive list it may be a timeliness issue for me. I may just bite the bullet on the ATE if Marks aren't available but am curious about a BMW or maybe Mercedes part that would work that is reasonably priced? Cheers
I have a 23MM Mercedes master cylinder on my /6. You will get a different pedal feeling for sure. I don't think it was the right choice for my setup (previous owner installed it) but it works for my leisure drives.
My brake setup (from the previous owner):
Porsche 911E front struts were installed in order to handle Porsche 911S "A" calipers.
New vented front and rear 911 brake rotors. All metal brake lines and rubber hoses were replaced.
The rear brake calipers are rebuilt and come from a Porsche 911S. Factory spacer shims added to the rear "M" calipers to accommodate the vented rotors.
A machined spacer was added to the inside of the new rotors to align the rotor centerline to the caliper centerline.
The parking brake system is now the Porsche 911 type brake shoes within the brake rotor design.
