QUOTE(Steve @ Jan 6 2016, 08:31 PM)
I still had gas starvation issues with my stock 3.2 DME motor. If the tank was half full or less, during hard right turns the motor would cut out. Since moving to PMS's fuel cell I no longer have any problems.
If you are having starvation issues the cheapest fix is to build a Surge Tank.
A surge tank example would be a 4" round vertical tube, could make it as high as the trunk bottom to hood. It has 4 ports, three top one bottom. It runs 2 pumps, the gas tank to surge tank is a regular carb pump using a top port to return, the feed is a FI pump and return.
Surge tanks can be as small as a couple liters for street, for race I'd make it as tall as you can.
Surge tank in the engine bay may work better for the 914.
http://www.sdsefi.com/techsurge.htm
