QUOTE(turnaround89 @ Jan 7 2016, 04:01 PM)
Hi Brad,
Would you consider this a roller(at least enough to be towed on a tow dolly) or would it need to be flat bed towed to location?
Would you have a cost on how much the suspension could be replaced for? Is it a new piece that needs to be welded onto the vehicle or just a bolt on?
I'm having a hard time seeing whats going on in the picture of the suspension.
Thanks so much!
Andrew, If the 1/2 axle were removed (not the stub axle) you could dolly it.
The RR suspension repair in a shop would run roughly $600 to $1000. (used vs. new suspension console) This car has had the inner console "smashed" upward, almost universally weakened by rust. The repairer just welded the damaged area which caused the camber on that wheel to be way off. This is a weld repair.
914 Limited Inc.
Brad Mayeur
1162 N. Byerly Hills Dr.
East Peoria, IL. 61611
309-694-1797
P914LTD@yahoo.com
