siverson
Jan 6 2016, 10:04 PM
i'm sure this is a dumb question, but who cares? How do I remove the main jets from the carburetor.
The car is running a little burbly. I know very little about carbs (always fi before this car), and a quick search says this is something that gets clogged and may need to be cleaned out.
but once I unscrew them, how do I actually pulled them out of this hole? They do not appear to be magnetic.
Thanks!
-Steve
siverson
914
siverson
Jan 6 2016, 10:05 PM
914
toolguy
Jan 6 2016, 10:50 PM
That's not the main jet. . that is the air correction and the emulsion tubes
Mains are at the bottom of the float bowls below the drain plugs..
Most common trouble is plugged idle jets.
siverson
Jan 6 2016, 11:13 PM
Eric_Shea
Jan 6 2016, 11:20 PM
Everything in the picture is right and so is toolguy
Air correction adjustment and air correction jets are not the same thing.
Mains are at the base of the float bowls. Be prepared with a small glass to collect the fuel and I hope you like smelling like gas.
The air corrections are up top where you are looking. They will screw out with a screwdriver and then use a fat toothpick to stab them in the air correction hole.
Eric_Shea
Jan 6 2016, 11:23 PM
Wait... Just read further (I'm on my phone sorry) the blue is NOT the idle jets.
I'll try to explain as best I can without being able to draw more arrows.
Look at the line that separates the top from the body of the carb on the right. Just below this line there are three brass covers. Your idle jets hide in there (not your mains).
Your "Mains" are at the bottom of your float bowls. Carb on the right again, look at the bottom of the two float bowls. The bowl on the left has two main jets in it and the bowl on the right has one main and one empty plug.
Give me a buzz tomorrow and I'll go over some carb stuff, hopefully make it easy for you.
Luke M
Jan 7 2016, 08:51 AM
Check out this link :
http://www.performanceoriented.com/index.htmThere's lots of good Weber info on this site.
siverson
Jan 20 2016, 06:43 PM
Thanks for the tips.
I haven't really learned anything yet, but I did get him running well again. I just removed the 6 things circled here (6 on each side), blew them out with compressed air, sprayed some carb cleaner around, and now he sounds great again.
Nothing *looked* clogged, but there must have been something in there because that made a world of difference.
Vroooom.
-Steve
