Hi All,
OK, so I have the axle removed along with the brakes, etc. Have loosened all the bolts but have not dropped the trailing arm yet. Had a couple of amateur questions before I do.
1. It almost seems like the pivot shaft will get hung up on the metal near the rocker panel. Do I simply remove the 3 bolts on the link bearing (item 5) and then lower it from that side to fanagle the pivot shaft out.
2. I see reference to marking the the shims. As I can not see the shims until the link bearing is removed, what / where exactly am I marking?
3. What is best way to remove the rear wheel hub (I do have a press). Do I unbolt item 11 (bearing cover?) before I press or pull the bearing or hub out?
Thanks.
