injunmort
Jan 7 2016, 04:02 PM
happy new year to all. I am in the middle of a motor swap and I took pressure plate off to renew the seal. I washed the index mark off when cleaning the pressure plate. I am reusing clutch and pressure plate as they are in decent shape. is there a way to re-index the pressure plate or should I not be too concerned with the balance of it?
76-914
Jan 7 2016, 04:03 PM
no problemo
screenguy914
Jan 7 2016, 06:09 PM
If they were previously balanced as a unit (matching index marks?), I would reinstall as a balanced unit. Balanced assemblies are usually marked with punch marks, not with temporary ink marks.
It'll work in a random fit up, but there may be vibrations which could either be disconcerting, not discernible and/or shorten bearing life. YMMV.
Sherwood
Sherwood
injunmort
Jan 7 2016, 06:20 PM
it was definitely balanced as a unit, drillings on the outer ring. would the corresponding punch marks be on the flywheel? the index mark that washed off was put on by me before I disassembled.
LowBridge
Jan 8 2016, 06:36 AM
QUOTE(screenguy914 @ Jan 7 2016, 07:09 PM)
... if you can't find the punch marks then it was not balanced
injunmort
Jan 8 2016, 07:45 AM
thank you
