Cfletch
Jan 7 2016, 06:54 PM
Finally getting back into my project, school got in the way for a little bit. Anyways, I've got a 2.7 with CIS and am curious what ID of fuel line hose I will need for both the to and from past the tunnel lines. I have the SS tunnel lines installed in the car and am just not sure what size I need to run for all of the flex line from there through the filter, pump and accumulator all the way to the engine. Is there a specific size to run or am I just over thinking it? Also how much roughly would I need?
Thanks!
0396
Jan 7 2016, 07:19 PM
There was a tread on this...search is your friend.
colingreene
Jan 8 2016, 02:21 AM
hes got 96 post, Maybe help him out?
Cfletch
Jan 8 2016, 10:53 AM
Sorry, I'll do some searching.
0396
Jan 8 2016, 01:29 PM
QUOTE(colingreene @ Jan 8 2016, 12:21 AM)
Sorry for my suggestion. Since I was not able to assist. Maybe you should search for and post it for him?
ChrisFoley
Jan 8 2016, 03:33 PM
For a 8mm stainless line use 5/16" ID 30R9 rated hose and for a 9.5mm stainless line use 3/8" ID hose.
As long as the fitting dia is the same at both ends of the hose you don't need an adapter, but if the two hard ends are different you should use a hard adapter and two different dia hoses.
Series9
Jan 8 2016, 05:44 PM
Don't overthink it.
The factory supply/return lines are more than adequate.
screenguy914
Jan 8 2016, 06:20 PM
I'd like to move the fuel pump into the trunk area for easier access. How much flex hose (8mm?) do I need to make future fuel tank removal convenient w/o removing any hose connections?
Sherwood
Series9
Jan 8 2016, 06:23 PM
I place FI pumps outside the hole, between the steering rack and the body. It makes plumbing and service remarkably easier.
colingreene
Jan 8 2016, 08:46 PM
QUOTE(396 @ Jan 8 2016, 11:29 AM)
Thanks sassypants.
Im on a phone, and i asked for you to find it because you had indicated that you just saw it.
