QUOTE(vintage914racer @ Jan 9 2016, 01:26 PM)
Nice work. Have you tried it out on track yet?
I've heard that he outlet should be something like 1.6x the size of the inlet. It's hard to tell but it looks like your outlet might be smaller than the inlet? Not trying to criticize at all and I get that you have limited space with the fuel cell in the way. I ran into the same problem with mine. I've made a couple out of aluminum, but am thinking of going the fiberglass route before next season.
Very good point........ it is hard to see but the oil cooler is sticking out halfway under the floor board and is wide open to the air flow under the car coming in through the opening in the air dam. The upper half of the cooler is sticking out above the floorboard as shown in the photo. This slit I cut in the floorboard is to allow air from the top of the cooler that is above the floorboard to exit out the bottom. The duct is for this air only.
I have not tried this on the track yet.
The RX-7 oil cooler works fantastic while the car is sitting still and getting hot. I can put my had on the other side of the fittings and it is cool to the touch where the fitting end at the inlet is really hot.
I learned this RX-7 oil cooler trick from my friend who owns the Elliot Forbes Robinson racing 914.
Yes, fiberglass is always better than trying to fab out of sheetmetal.
