Always Looking
Mar 17 2005, 12:34 AM
Does it matter which FI I attach to the two plugs from the harness on either side of the engine? Also, does it matter which way the plug inserts into the injector? If either does matter, how do I set them up correctly. (Sorry about the novice terminology.)
72 1.7 FI
Dave_Darling
Mar 17 2005, 12:43 AM
It does matter which wires you plug into which injector. They originally had different-colored "boots" on them, black and grey. I recall that the black ones went on the rear-most injectors?? To be sure of which is what, though, you will have to unplug the connector at the ECU and use a continuity tester (or ohmmeter) to check which pin numbers the various injector plugs are hooked up to.
If you get them wrong, the car will run--but it will be a little "off", particularly at idle and lower RPMs.
You can plug the plug into the injector any which way, as far as I can tell it doesn't matter. The plugs themselves have two beveled corners, but the sockets in the injectors don't have the bevels to match--so I'm pretty sure that Bosch didn't think it mattered which way around they were either.
--DD
