QUOTE(Dave_Darling @ Jan 12 2016, 07:49 AM)
QUOTE(jpk @ Jan 11 2016, 09:03 PM)
I thought the six bolts up to the type 4 914 trans axle?
It does, but that's the least of the work. You'll need engine tin to fit the 914 chassis, an oil tank and oil lines, a motor mount, an exhaust... And about eleventy zillion things that weren't obvious at first.
The 1.7 has to be replaced to be able to go to large on the tyor 4 correct?
You can build any displacement Type IV engine on pretty much any Type IV case. So you could build your 1.7 up to 2056cc if you choose. Though it would be easier to start with a 2.0 motor, because that would already have the 71mm-stroke crank.
The car i have has the fuel injection system intact, is it able to be modded to handle the more aggressive cam and displacement?
Not really. While you can do a fair bit with very fine tweaking of the stock system, it starts running out of adjustment when trying to work with even a modestly aggressive cam. There's always the Megasquirt option, of course, but that can open you up to a whole new world of tweaking and adjusting.
Im hoping for like a 13#/ horsepower.. 150hp for 2000# car.
A solid 150hp is probably not going to be that easy for a 2056cc engine, though of course a lot depends on exactly what you're willing to do to the engine itself, and what compromises you're willing to live with in the name of power. Though you might be surprised at how fast a 914 can feel with just the stock 1.7's 80 HP...
Be aware that going to a Six will add a couple of hundred pounds to the weight of the car. (It'll also produce some of the best engine sounds ever!!)
--DD
I really appreciate the advice .
Does the 200# make a huge difference? its what 10% of the body weight
I thinking that I should run before I walk.... Get it running and decide what makes sense.
The hotrodder in me has a hard time not souping up something with 80 hp.. lol
The zero to sixty time is 12.4 seconds in the 914 my falcon does the same time in the quarter mile.
What is the down side of the big bore type 4 that you mentioned , keeping in mind i;m hoping for a street driven track toy.
I bought the car for $600 ,so I feel i'm already money ahead.
I'm really looking forward to discovering the car that has so many people excited!
