Aaron Cox
Mar 17 2005, 09:46 AM
today im installng the new oil pump. I remember i packed the last one with vaseline, what should i pack this one with?
AA
Type 4
Mar 17 2005, 10:06 AM
Yes a small amount of vasoline wiped on the gears will help it prime.
Demick
Mar 17 2005, 10:08 AM
I packed mine with the same engine assembly lube that I used everywhere else. It was basically a very lightweight white grease.
Demick
Thorshammer
Mar 17 2005, 10:14 AM
Engine assembly lube has some moly in it, but use it sparingly. Do not over pack the pump, you just want it to draw a good vacuum intially, I fill the oil cooler and the pressure sending unit hole, and the filter with oil before I try to turn it over, and without the plugs in as well. Also Make sure the battery is in good condition and the motor spins over quickly, this will help.
Erik
Rusty
Mar 17 2005, 10:58 AM
With that question coming from you... I would figure the answer would be clear.
FUDGE!
-Rusty
P.S. Damn, I'm tired. Funny, too...
ChrisReale
Mar 17 2005, 01:33 PM
QUOTE (Lawrence @ Mar 17 2005, 08:58 AM) |
FUDGE!
-Rusty
P.S. Damn, I'm tired. Funny, too... |
that was the first thing I thought about! Sorry Aaron, but your 914Club destiny has been chosen for you
nebreitling
Mar 17 2005, 02:02 PM
sorry.
type47
Mar 17 2005, 02:55 PM
how about discussing reusing old oil pumps..... how do you check one to see if it's still in spec? what are the specs?
Aaron Cox
Mar 17 2005, 03:08 PM
you guys suck
MattR
Mar 17 2005, 04:05 PM
aww aaron,
