I have come up with an improved method for stretching sheet metal. In my first video I use a palm nailer with a carriage bolt in it for stretching really fast which leaves lumps that must then be hammered out. The new technique will be in my next video, but I thought I should share it now so here goes...
Leaving the carriage bolt in the palm nailer, I made a hammer head from flat bar and a short piece of tubing. The flatbar has been ground, filed and sanded to a compound shape. I wrapped some electrical tape around the sleeve of the palm nailer to tighten up the fit a little. It is nice to have a little wobble in the fit, just not too much.
Then I held a piece of steel over the shot dolly, and stretched down into it. The pictures show the tool and the sheet metal. You can see that there is a pretty smooth lump. This took about a minute to do, and will require very little work to be perfect. I will be using this method with a slight variation in my next video. I will hold the shot dolly on the outside of the fender flare, and use the palm nailer from inside instead. I'm excited about this development...it should make the work faster and easier...although no less noisy.
You can also use the palm nailer from the outside, and hold a dolly on the inside for smoothing purposes...a little tricky.
For those unfamiliar with the tools:
http://allshops.org/cgi-bin/community/comm...d=9980138836765
Pictures attached.
John www.ghiaspecialties.com
