I know it has been listed before, but time has passed and I needed clarification from the experts that have already completed their conversions.
I am using a Meziere 55 GPM pump on my LS conversion and remember comments that a Toyota Supra or similiar car radiator was utilized .My questions are as follows:
Which Meziere pump is best and how was the thermostat handled since it is removed with the stock pump? Am I close to remembering the Toyota Supra radiator? (Thanks Andy)
Also, I received the attached response from Meziere and wondered if someone had a water routing diagram to help in designing the system .
We do sell the WP316 water pump and others for the conversions. In the typical LS remote water pump you would run the 2 lines coming out of the pump go to the two lower ports on the front of the engine. The two upper port normally tee into 1 line at the engine and the thermostat would go in this line returning to the radiator. (Thanks to Jerry from Meziere)
Thanks to all for your continued support and guidance!
