here's another thats helpful:
Full Synchro Swap on 901I swapped my 912 gears out last week for 914 gears- just the 3/4/5 gears. I'd never worked inside a trans before, was a 1st for me.
It wasn't typically like an "easy" job...but if you're decently mechanically inclined you can do it. It NOT real hard. The ONLY thing you can screw up is getting the pieces back on in the wrong order. if every spacer and shim goes back where it was then you're set.
