All very good advice and appreciated - but not, in this case, a solution. For some odd reason, this motor was built with a markless fan / and worse yet, no wide fan blade at the 34 degree area....
However.... In order to get in a nice SoCal PCH ride in today (after four soaking freezing days in Seattle looking for another 914 - that never showed up....) ... I found a solution... back in SoCal.
Get the dwell angle perfect with the SunPro - between 45 and 50..., and make sure the points are clean and the lobes are lubed / get the rotor pointed directly over the notch in the rim of the dizzy, then pluck #1 plug and put a chopstick in the hole resting against the top of the cylinder,.. //// use a rubber band connected to a carb fitting to apply gentle tension between the chopstick and the threaded area where the plug goes into the head,.... then watch the chopstick move back and forth until you find best real TDC* .
Then mark the markless fan with whiteout in the "V" notch.
Next dial in 35 degrees of advance on the adjustable timing light and fire the little 2.2L puppy up while adjusting the dizzy to get your mark in the middle of the notch at 3200 to 3500rpm's at advance / then drive it very hard to see if all is good.
All is good. See you in Are-we-gone
* Ancient Chinese proverb: If your tool is not centered and deep in its correct place (the hole), no amount of moving back and forth will find true center or enlightened happiness (TDC)
Sidebar: If the mark is not precisely in the correct place on the fan as marked, use a small flat paintbrush with thinner to take the whiteout off and do it again....
What are Sunday's for..
