QUOTE(mb911 @ Jan 18 2016, 04:27 PM)
Guys as I finish up the 914-6 oil tanks I will be moving on to making the oil fill necks. Could anyone out there measure/dimension the dipsticks for me ?
Tried to take a picture, but it didn't come out well enough.
Mine is 33cm from one end to the outer end of the loop/handle.
The loop is 3.5cm and rests against the dipstick hole/pipe.
The very end of the stick has a notch, I assume to indicate low oil level.
9cm up the stick is a dot which I've always used as the full marker.
The stick itself is flat steel 1mm x 5mm, slightly curved.
