QUOTE(jkb944t @ Jan 21 2016, 09:11 AM)
QUOTE(cary @ Jan 21 2016, 07:01 AM)
How old is the car ?
It is a 2009 so I was rather surprised. She took it to the Audi dealer and they told her that it wasn't an OEM windshield so they couldn't fix it. She has had the car for about two years so the windshield was replaced before she owned it.
Jeff B
Jeff,
Before she does anything with it - if it's still under the factory original or CPO warranty, then she & you should press Audi to fix it since the body/paint should still be covered under the rust-through aspect of the body/paint warranty regardless of the windshiield (unless they can point to a specific wording in the warranty to defeat it) - that is, if it's still covered as a 2009 in 2016 (or whenever she first took it to Audi dealer as the report date if earlier).
If not covered, then the cleaning, rust converter, prime & touch-up paint route is the best temp solution. Either paintscratch.com or drcolorchip.com should be able to match the paint from the paint code, in paint pen, small bottle to cans & rattle cans - depending on the area to be covered. You should be able to find a store which supplies paint shops to get the range of grit up to 2000 to do color sanding for an unnoticeable finish.
But you might want to use Wurth Zinc Rich Primer (or Eastwood's), to give a sacrificial zinc coating similar to the original body hot dip rust proofing, since it will continue to be subject to road-spray laced with the winter road salts - which is the likely cause of the rust, perhaps brought on by a chip or flaw in the paint in that area.
The paint at the windscreen frame should've been a continuous covering under the gaskets & glass etc., & therefore protected by the warranty - so it's surprising to me to see it rusting there so soon, but that frontal area is subject to a lot of wind & turbulence induced road-spray.
Good Luck!
Tom
