Korijo
Mar 17 2005, 10:37 PM
i started thinking "they" wont ever be ready
should i go 5 lug?
i picked up some early hubs from V.Delgado (finally got 'em
), so i'm a 1/4 of the way there
Mueller
Mar 18 2005, 12:04 AM
4 lug versions are done, they should be shipping in a few weeks...I wouldn't hold my breath for the 5 lug versions to happen any time soon.....
Korijo
Mar 18 2005, 12:46 AM
i
want the 4 lug ones. shipping where? i still need to buy them
Bleyseng
Mar 18 2005, 08:19 AM
Aw, come on Mike. Please make some 5 bolt hubs as I don't want to wait too long. (6 months maybe?)
Geoff
Root_Werks
Mar 18 2005, 09:15 AM
I am on the 5 lug bandwaggen myself. I am close to buying a 911 front end or the billet hubs. If they ever do get ready, just let us know.
machina
Mar 18 2005, 09:23 AM
QUOTE (Root_Werks @ Mar 18 2005, 10:15 AM) |
I am on the 5 lug bandwaggen myself. I am close to buying a 911 front end or the billet hubs. If they ever do get ready, just let us know. |
Me too.
Bleyseng
Mar 18 2005, 09:26 AM
Come on Mueller, you are losing sales here!
Mueller
Mar 18 2005, 09:31 AM
QUOTE (Bleyseng @ Mar 18 2005, 08:26 AM) |
they are not mine, they are Brads.....his been "busy" lately
Root_Werks
Mar 18 2005, 09:40 AM
QUOTE (Mueller @ Mar 18 2005, 07:31 AM) |
QUOTE (Bleyseng @ Mar 18 2005, 08:26 AM) | Come on Mueller, you are losing sales here!
they are not mine, they are Brads.....his been "busy" lately |
Hard to dispute that one!
SteveSr
Mar 18 2005, 09:47 AM
QUOTE (Mueller @ Mar 17 2005, 10:04 PM) |
I wouldn't hold my breath for the 5 lug versions to happen any time soon..... |
Isn't it just drilling a five lug pattern???
SteveSr
Root_Werks
Mar 18 2005, 09:59 AM
QUOTE (SteveSr @ Mar 18 2005, 07:47 AM) |
QUOTE (Mueller @ Mar 17 2005, 10:04 PM) | I wouldn't hold my breath for the 5 lug versions to happen any time soon..... |
SteveSr |
Actually, If I could get a set of 4's, I could re-drill them to 5's. Soooo, Mueller, how much for a set of hubs? Can we just order them through you?
TravisNeff
Mar 18 2005, 10:22 AM
Or one option would be that it wouldn't be drilled for lugs at all, then your wheel options/bolt patterns really open up.
914werke
Mar 18 2005, 10:36 AM
Mike did that cap dimension work out or did you need it in mm?
Mueller
Mar 18 2005, 12:33 PM
QUOTE (rdauenhauer @ Mar 18 2005, 09:36 AM) |
Mike did that cap dimension work out or did you need it in mm? |
I meant to ask you:
does the 911 dust cap mount on the inside or outside of the hub?? I've never seen one up close and personal , on the 914 hub, it mounts on the outside...
QUOTE |
Or one option would be that it wouldn't be drilled for lugs at all, then your wheel options/bolt patterns really open up. |
Well, we kind of screwed up here, I added 4 pockets in between the 4 holes for the studs/lug bolts, so currently, they cannot be redrilled for a 5 lug pattern...they "might " be able to be redrilled for a 4x100 pattern if one so desires....if another batch is made, then yes, we can leave them more or less "blank" and leave them unfinished until an order is placed.
Root_Werks
Mar 18 2005, 12:57 PM
QUOTE (Mueller @ Mar 18 2005, 10:33 AM) |
QUOTE (rdauenhauer @ Mar 18 2005, 09:36 AM) | Mike did that cap dimension work out or did you need it in mm? |
I meant to ask you: does the 911 dust cap mount on the inside or outside of the hub?? I've never seen one up close and personal , on the 914 hub, it mounts on the outside...
QUOTE | Or one option would be that it wouldn't be drilled for lugs at all, then your wheel options/bolt patterns really open up. |
Well, we kind of screwed up here, I added 4 pockets in between the 4 holes for the studs/lug bolts, so currently, they cannot be redrilled for a 5 lug pattern...they "might " be able to be redrilled for a 4x100 pattern if one so desires....if another batch is made, then yes, we can leave them more or less "blank" and leave them unfinished until an order is placed. |
911 inside.
Bummer on the 5 lug hubs. I am sure if or when they ever refined, they will be a hit!
LouisCypher
Apr 1 2005, 02:48 AM
Hi there,
when are the 4 lug hubs coming? Are there any pics available? I remember having seen them here but i cannot find the thread. Anybody got the link?
Cheers,
Louis
LouisCypher
Apr 3 2005, 08:43 AM
Hi,
OK, I have found the original thread and the pics. Thanks for "all" the replies
So when will the hubs be available, then?
Thx,
Louis
