QUOTE(Unobtanium-inc @ Jan 22 2016, 03:04 PM)
Whatever you do, don't fall into the trap too many guys fall into where they take the car apart down to the last nut and start cutting out bad metal, then get overwhelmed because they can't remember how anything went together or how to fix what they cut out. Pick on spot on the car, fix it, seal it, and move onto the next spot. It's not as fun and dramatic as tearing the car apart, but it will keep you much saner about the project. I have bought dozens of cars from guys who got in over their heads and took a bath on the car when they sold it.
Body has been done and repainted.
Needs reassembly now.
PO did a lot of the work. Going to work on the interior until it warms up around here!
May pull as many interior parts into the house to clean up and see what needs repair and go from there.
I'm thinking a package deal from 914 rubber in my future and maybe a wire harness.
Although, I would like to hear the engine run before replacing wiring. Kind of a vicious circle whether to do all the wiring first or put together and see what works and replace wiring as needed. Although I think wiring is going to be a lot easier without everything installed and put together.
First step, Organize, and document (go through all the boxes, trunk, extra parts). Then sort out my strategy.
Thoughts?
