QUOTE(flmont @ Jan 25 2016, 05:16 PM)
Chris 914 ,..Yep trunk space,want to run line thru the longes on either side,..and Mueller,..well if they can build it,.. Iam thinking pet-cock on top of one side,to bleed and 1 at bottom to drain,..???
No brainer.. I have trunk space
Run rubber hoses under the car, it helps with cooling.
Most filler neck less radiators have a high mounted petcock for bleeding. If you know what side the fill neck will be on have it put on the same side, otherwise ask for one on each side so you only need to jack up one side of the car for filling & bleeding.
Don't listen to old folks with old info
single row single pass is the prefered design for the modern aluminum radiators and use high flow fans, or in the case of the Celica- stock fans. Don't trust the specs of chinese made fans.
The performance rad Bellis uses is a good choice for I'd say up to 300hp.
