QUOTE(mskala @ Jan 24 2016, 10:15 AM)
Okay, I've never been able to get the muffler on the -6 to mate to the headers
without leaks at either the top or bottom. It seems like a stupid design, with only
the 2 bolts and no strap to hold the weight of the muffler like on the 911.
Click to view attachment I'm using the copper covered gaskets. Is there some kind of trick to making it work?
A real /6 doesn't have a muffler hanger like a /4?
That is odd. If possible I'd fab a hanger like a four.
Coming from a VW beetle/bus (then 914) background every single failure I see like this is related to lack of support of the muffler.
A large number of head exhaust stud failures are also related to this issue.
Most likely culprit is one of the flanges is thinner than the other and when it has been cranked down too hard it bent the flange. And/or this also crushes the gasket at the bolt holes causing a leak.
This relates to the muffler hanger issue, because as the joints rattle loose the owner cranks down the flange bolts tighter and tighter bending the flanges.
