So I got an Airtek pump installed this afternoon and after some troubleshooting I was able to get the pump running. However, the pump is not sucking fuel and I can't imagine it would need to be primed???
The tank was dry so I added 2 gallons which I can now see in the tunnel fuel line (yes I have the old lines in the tunnel still).
The pump is located on the firewall not in the original location. With the firewall mounting the inlet is very close to the tunnel so routing the lines to the inlet requires a couple 90 deg sweeps up to the inlet with the filter in between.
The only reason I can think of for the pump not sucking would be:
1) Faulty pump
2) Leak somewhere in-between the pump and where the line exits the tunnel
3) Bad fuel filter
4) Maybe my 90 deg sweeps to the pump are to restricting??? Perhaps I should run a length of pipe around the pump that sweeps into the pump inlet???
I know a few others here have used this pump which seems to work very well.
Anything you can offer would be helpful!
Many thanks!
