QUOTE(Highland @ Jan 25 2016, 07:47 PM)
So about 500 miles after a rebuild my engine seized on a gear change. Finally got it tore down and this is what I found. Engine is a stock 2L with RAT 9590 valve train.
Click to view attachmentI'm thinking 3 things could have caused this all related to improper bearing crush.
1) I didn't torque the case correctly.
2) Align bore was not done correctly.
3) Defective bearing.
How do I determine the root cause so I don't repeat it?
I'm hoping the case is still useable. Last time it was align bore to .020, but I noticed Type 4 store sells .030 over main bearing.
I'm assuming the crank is unusable. Can someone tell me the source of a stock 71mm 2.0 crank.
Sometimes common for people to rush fitting the crank and not locate the dowels properly its just sloopy work practice sorry...however how did you not notice the crank was tight as you torqued the case, you would be checking this though the whole process off assembly.
These bearing can be very hard to get off as the whitemetal peels of the bearing shell and sticks it all up on the journal of the crank.
Usually the crank will polish up again if you haven't run the engine long.
The line bore should be fine and its won't be a bad bearing,next time do a dry fit of the crank (no case sealer) and continually rotate the crank and check for tight spots,the dowels must be located correctly in the bearing.
