80cap
Jan 25 2016, 06:44 AM
I purchased a new cable and guide from 914 rubber and went to install
it, the t handle is locked and the keys I have don't work. They don't work on
any of the locks. Do I need to drill out he tumblers or any suggestions.
Thanks Brian
johnhora
Jan 25 2016, 07:47 AM
Are you able to get into the front trunk?
If not you will have to remove the front bumper and there is a hole in the center of the front body metal right where the latch is located...you can open the lock there.
Then you can remove the T handle...there are two small allen head bolts that hold it to the body....soak then good as they are usually hard to remove
80cap
Jan 25 2016, 07:53 AM
Yes the trunk lid is off. I see the two screws and will remove the t handle.
once its off any suggestions on how to rekey?
TheCabinetmaker
Jan 25 2016, 08:25 AM
You can send it to me and I'll fix it for ya.
