CatDaddy60
Jan 25 2016, 07:47 PM
I'm pulling apart a mystery engine that was purchased from a junk yard from a car that was set up for carbs but the carbs were long gone. The car had a low pressure fuel pump mounted on the firewall,, The cylinder heads have the mounting for a cylinder head temp sensor but one was not mounted. I'm looking to see if anyone has changed to a aftermarket cam. Can anyone tell me what markings came on the stock 1.7 , 1.8, and 2.0 cams.?
TheCabinetmaker
Jan 25 2016, 08:17 PM
No markings on cam. Part# is on the cam gear.
CatDaddy60
Jan 25 2016, 08:39 PM
QUOTE(The Cabinetmaker @ Jan 25 2016, 06:17 PM)
So if there was 245 cast into the cam is it a possible aftermarket cam?
914Sixer
Jan 25 2016, 10:06 PM
Yes it probably aftermarket. Some factory cams DO have part numbers on them. Most are not readable though.
CatDaddy60
Jan 26 2016, 12:51 PM
QUOTE(914Sixer @ Jan 25 2016, 08:06 PM)
Thank you
nathansnathan
Jan 26 2016, 01:09 PM
A stock cam would have a rivoted on gear, an aftermarket cam would have the gear bolted on. Also I think the original cam gears all have vw logos cast into them?
