Qarl
Jun 13 2003, 05:45 PM
Here is my mostly collected rear suspension setup...
From the top down...
9x16 Fuchs - dual annodized rough and clear
Trailing Arm Reinforcement Pieces
Mueller's Trailing Arm Needle Bearings (From the Korijo Auction plus the setup for the front A-Arms)
Early 911 Hubs and Stub Axles and studs (need to be bead blasted)
New annodized lug nuts
Bilstein Sports with H&R Springs and Adjustable Perches
New Bearings
I finally took all the crap out of boxes and decided to start laying out parts by sytem and organize stuff in bins and on tables.
Regards,
seanery
Jun 13 2003, 08:35 PM
probably need another wheel, huh?
Qarl
Jun 13 2003, 08:37 PM
Damn it! Forgot to check the box before I threw it out!
Oops!
Naw... I've got three more (one more 9 incher and 2 8 inchers.
Karl
seanery
Jun 13 2003, 08:47 PM
which 8's are they 951 rears? I hope I haven't asked you that before.
Qarl
Jun 13 2003, 09:02 PM
944 (23.3mm offset) 8x16s
930 (15mm) 9x16s
seanery
Jun 13 2003, 09:53 PM
I'm using the same 8's when mine is flared (took em off my 951 and put BoxS wheels on).
TRE makes a 9 that looks like the old 10 and that is going on the rear.
Brad Roberts
Jun 14 2003, 12:41 AM
Looking good Karl..
I'm going to use 8's and 9's on the 3.6 car.. and do the wheels EXACTLY the way you did them. This is my favorite look for the Fuchs. I first saw them done this way on a 80's poster with a convertable red slant nose wide body car. I have loved the looks since then. It will really look good against a black car.
B
Qarl
Jun 14 2003, 07:33 AM
Thanks... I have seen a few pics of some European GTs in Yellow and Red with these wheels... drool!
maf914
Jun 14 2003, 08:09 AM
Karl,
I know this has been discussed in various posts before, but what combination of rear hubs, stub axles, bearings, CV joints, axles, and drive flanges are you using to go to five lugs at the rear? Thanks.
Mike
Gint
Jun 14 2003, 03:28 PM
Karl,
Did you send your wheels to WE and have them done? Or did you buy them direct from them? How much? I'm interested in that finish for my set of 4 6x15's.
Qarl
Jun 14 2003, 03:36 PM
I would check with Al Reed (check the Pelican 911 board for his phone number). he can probably do it cheaper than Wheel Enhancement.
I bought my wheels from them, but I think they want $160 or so per wheel for the dual annodized (rough clear) finish. This was for larger 8x16 and 9x16 wheels. It may be less for smaller wheels.
But check with Al Reed first... he is much cheaper and does as good if not better work
Essentially they annodize the entire wheel in the clear finish, then block off the padles and rims and bead blast the background for a dull (rough) finish.
Here is another (generic) shot.
Gint
Jun 14 2003, 03:48 PM
Thanks
