wndsnd
Jan 27 2016, 03:17 PM
Could I get enough heat to take the edge off and maybe defrost by running a duct behind a front oil cooler to the inside with maybe a slide valve?
Tom_T
Jan 27 2016, 03:33 PM
John,
The typical solution is to add on the factory style 75-76 MY heater hose "Y" splitter at the fan with ducting to the right side tube on the Pass. Longs to the Pass. side vents & effectively doubling & better distributing airflow.
Ideally, Porsche/VW would've designed it with a fan each side L & R from the flapper boxes to both shorten the air hose run to the Pass. side & double the airflow from 2 dedicated fans.
Also, warming the engine up will get it hotter in cold weather. that always worked for me, so long as the T-stat is properly set & operating.
And before you say we don't have any cold weather like yours in SoCal - I used to take my 914 up to local CA mountains, Mammoth, Tahoe & Utah etc. ski resorts in just as cold winters as you have, back when it was my DD 75-85.
IMHO your passing by the oil cooler would just introduce colder air - or not as warm nyway - into the ducting system.
Cheers!
Tom
wndsnd
Jan 27 2016, 03:41 PM
Hi Tom
I probably should have explained better. Doing a six conversion and thinking about headers without heater boxes.
I do not drive in winter here because of the salt, but I have thin blood and get chilled spring and fall, and would like defrost.
Front oil coolers are a pricey addition, but probably necessary and I thought I might extract some free heated air.
Jan 27 2016, 04:00 PM
John - I don't think you'll get enough heat off that cooler if any during the winter to make it viable. Chances are your on engine cooler is enough to keep the engine cool during the winter and not much hot oil will even head forward. I would go with heated seats (easy to retrofit) or heated seat covers. There should be enough juice from the 6 alternator to power them. Start out in a heated garage.
Spoke
Jan 27 2016, 04:12 PM
QUOTE(mepstein @ Jan 27 2016, 05:00 PM)
In the winter, my 930 only gets hot enough until the oil cooler valve is opens. The engine temp stops abruptly at that point. In the summer, the engine temp cruises right by that point to a much hotter place.
BTW, if you use the oil cooler for heat, you won't have any heat until the oil cooler valve opens up.
wndsnd
Valid point. When it is cool enough for me to want heat, the front cooler would probably be bypassed.
r_towle
Jan 27 2016, 04:43 PM
no, thermo dynamics....wont do what you need.
Rich
jmill
Jan 27 2016, 07:22 PM
jmill
Jan 27 2016, 07:30 PM
wndsnd
Jan 27 2016, 07:38 PM
40 amps!
914_teener
Jan 27 2016, 07:45 PM
QUOTE(wndsnd @ Jan 27 2016, 05:38 PM)
40 amps!
No.
This idea was discussed to death a while back.
Tbrown4x4
Jan 27 2016, 07:46 PM
I hope this fits the conversation. Is there any info on CFM for the heater blower in the back? I thought I read that a bilge fan (for instance) wouldn't have enough flow. I think 2 fans would be a good solution if you could find something compact enough.
r_towle
Jan 27 2016, 08:21 PM
John, do you have headers or holy heat exchangers?
Either one, bring them over here, we can make it work.
wndsnd
Jan 27 2016, 08:34 PM
QUOTE(914_teener @ Jan 27 2016, 08:45 PM)
40 amps!
No.
What electric? Or sucking off the front oil cooler?
wndsnd
Jan 27 2016, 08:35 PM
QUOTE(r_towle @ Jan 27 2016, 09:21 PM)
Dreams right now ...
jmill
Jan 27 2016, 08:37 PM
Ok, electric is out. Why not run two coolers up front with one as a heater core. You'd need to run two sets of lines up front or place the thermostat after the heater core cooler.
914_teener
Jan 27 2016, 10:20 PM
QUOTE(wndsnd @ Jan 27 2016, 06:34 PM)
40 amps!
No.
Actually both....can.t find the thread right now.
Doesn.t Chris Foley make heater boxes for headers?
wndsnd
Jan 27 2016, 10:54 PM
Yep, but not looking for heater boxes.
ThePaintedMan
Jan 27 2016, 11:32 PM
Why is electric out? A couple years ago, as a poor grad student my main driver was down and I had to resort to driving the 914 about 1.5 hours to and from my internship during the winter. I ran a Harbor Freight 12V heater to take the edge off, though of course it doesn't produce feet-burning heat. It would blow fuses when plugged into the factory cigarette lighter outlet, so I wired 12V direct from the battery into the cabin with a 15A fuse. It's doable with a very small amount of work and easily reversible and contrary to popular belief, in a small car like a 914, it does make a difference. You could probably even get away with a larger heater, at least for short periods of time and the correct wiring and fuse.
r_towle
Jan 27 2016, 11:37 PM
QUOTE(wndsnd @ Jan 27 2016, 11:54 PM)
Ah yes, but they will find you.
The key is defrost to get to the event on time.
Oil, you would wait 30 minutes.
Look at the gas heaters, still available, bolt into the front trunk.
Jan 28 2016, 05:46 AM
QUOTE(ThePaintedMan @ Jan 28 2016, 12:32 AM)
But you are in florida and john is in Massachusetts. He might have to stuff it down his pants before he felt any heat.
MJHanna
Jan 28 2016, 07:12 AM
If I read it correctly YOU get cold. If that is what you are trying to warm up put seat warmers in your seats. they are easy to do and you can do both seat for about $80.00. They work great at taking the "chill' off your body.
worn
Jan 28 2016, 09:29 AM
QUOTE(wndsnd @ Jan 27 2016, 01:17 PM)
I am looking at a diesel cabin heater. Wondering if it can go in the right rear fender well? Sort of a twin to the oil tank. Dimensions say it works, but anyone tried it? A good location for ducting into the existing ports.
JmuRiz
Jan 28 2016, 09:42 AM
Just wait till mb911 comes out with his stainless heat exchangers
wndsnd
Jan 28 2016, 10:18 AM
All good suggestions.
I have one of those conversion spreadsheets that has way too many line items on it, and am looking for ways to cut it down and possibly get it done for this summer. If I have to put it off another year to finish so be it.
The 1.7 in it now has SS exchangers, flapper boxes, and everything but the original electric engine bay fan. It does basically just a good enough job to take the edge off. And yes, I don't have the blood circulation I used to...
The new engine is getting close to completion and I know when it is finished I will be antsy to get it in.
r_towle
Jan 28 2016, 10:50 AM
Put on the header, don't worry about heat, get it running.
Rich
wndsnd
Jan 28 2016, 11:27 AM
QUOTE(r_towle @ Jan 28 2016, 11:50 AM)
Rich
Kind of where I am at ....
PanelBilly
Jan 29 2016, 10:48 AM
I was hoping for heat in my car too, but put that on the back burner till I get more details sorted out on my car.
74ravenna
Jan 29 2016, 11:35 AM
John,
This is a pretty good match for you car.
wndsnd
Jan 29 2016, 11:54 AM
Already got one
Jeffs9146
Jan 29 2016, 02:11 PM
r_towle
Jan 29 2016, 02:56 PM
QUOTE(Jeffs9146 @ Jan 29 2016, 03:11 PM)
you gotta really want to buy one of these to find any pricing, dealerships, availability of a gas fired unit etc etc...
I wonder if they still make a gas one..
Rich
wndsnd
Jan 29 2016, 03:19 PM
My guess is these are all diesel
wndsrfr
Jan 29 2016, 08:36 PM
Try out a Gerbing's heated vest & gloves that the hard core motorcycle riders use....only draws about 10 watts & is very comfortable....
wndsnd
Jan 29 2016, 09:11 PM
QUOTE(wndsrfr @ Jan 29 2016, 09:36 PM)
This might be the best idea yet..
This stuff looks nice!
http://www.thewarmingstore.com/gerbings-he...hing-store.htmlThanks for the heads up
