Was originally planning just to have my fuel tank cleaned out but it did have some small leaks so had it resealed with the GasTank Renu service. The cut open tank, sand blast, weld it back up, and then treat inside. I figured they should do a better job than any over the counter stuff and $275 was not terrible. The real test will be how well it holds up in terms of peeling. While I try to avoid ethanol fuel, in my area that is not always possible.
Here are pics of tank. I had them leave the top exterior untreated so that I can just hit that with some Satin Black to look more original. The rest you do not see. One question, on the last picture there is a threaded insert in the top corner of the tank. I do not recall removing anything from there and want to make sure a part is not sitting in the shop where they did the work. What goes in there?
