Beebo Kanelle
Jan 29 2016, 08:20 PM
When I drive over a rough road, the rear trunk unlatches !
I close it and it seems secure; I can't force it open, can't jiggle it open; it just stays latched until I go over a bump.
I cannot see any adjustment - I know this is not supposed to happen.
I feel kinda stupid about this but I am out of ideas.
Is there a solution?
Any and all suggestions / remedies are appreciated.
Thanks
EdwardBlume
Jan 29 2016, 08:23 PM
They can wear out. Buy a new one or a better one....
wndsnd
Jan 29 2016, 08:26 PM
QUOTE(RobW @ Jan 29 2016, 09:23 PM)
Latch? Trunk? Car?
EdwardBlume
Jan 29 2016, 08:32 PM
QUOTE(wndsnd @ Jan 29 2016, 06:26 PM)
Latch? Trunk? Car?
Yeah. OK
The trunk lid has a spring surrounded needle latch. Over time the spring can wear and the needle wear.
I've seen new ones where the spring is too strong and it pushes a side up. The latch can also be adjusted by loosening the bolts and moving slightly...
whitetwinturbo
Jan 29 2016, 08:50 PM
..............drive on smooth roads
rick 918-S
Jan 29 2016, 09:22 PM
The pin wears. Also there it a plastic cup with a spring that wears out.
bandjoey
Jan 29 2016, 09:56 PM
I can't look now but doesn't mikey sell a repair kit ? One of our vendors does. Spring, nylon washer, etc
914Sixer
Jan 31 2016, 07:33 AM
You can take the upper off and loosen the nut. Adjust the rod a turn or so. Put back on and repeat process until you get the lid tight.
rick 918-S
Jan 31 2016, 08:22 AM
QUOTE(914Sixer @ Jan 31 2016, 07:33 AM)
Did that and every other trick I could think of. Mine was doing the same thing. Popped open while driving. Ended up welding and reshaping the pin. So either replace the pin or repair it.
Mikey914
Jan 31 2016, 10:08 PM
QUOTE(bandjoey @ Jan 29 2016, 07:56 PM)
Made the spring retainer sleeve, but I am working on a manual release so this would be an easy cross over part to make.
Mark
porschetub
Feb 1 2016, 02:18 AM
QUOTE(whitetwinturbo @ Jan 30 2016, 03:50 PM)
that's helpful....not,have a few more
gereed75
Feb 1 2016, 07:19 AM
QUOTE(Beebo Kanelle @ Jan 29 2016, 09:20 PM)
Thanks
I was able to fix mine by using a file to " sharpen" the detent on the latching rod. Take a look at the geometry of the latch mechanism and you will see where to file.
rmdinmd
Feb 1 2016, 10:42 AM
QUOTE(rick 918-S @ Jan 31 2016, 09:22 AM)
The welding is what I had done; don't remember if it was Clay or Brad that suggested it. But either way that was the fix.
EdwardBlume
Feb 1 2016, 11:28 AM
QUOTE(Beebo Kanelle @ Jan 29 2016, 06:20 PM)
Thanks
I have a good used one you can try out for free. PM me your coordinates.
porschefile2010
Feb 1 2016, 02:37 PM
[quote name='Beebo Kanelle' date='Jan 30 2016, 02:20 PM' post='2295980']
This happened to me some months back. My car is away at the moment so I can't get a picture for you but from memory there is a nut under the trunk lid that holds the spring in place and mine had just come a quarter turn loose. I pinched it up again and it has never done it again. may not be helpful as you seem to have tried most everything else.
914Sixer
Feb 1 2016, 05:18 PM
You CAN ADJUST the rod up or down by taking it off and loosening the top nut. In most cases the rod simply has to be lengthened.
rgalla9146
Feb 1 2016, 06:51 PM
QUOTE(914Sixer @ Feb 1 2016, 06:18 PM)
I agree.
Most likely the pin is not long enough.
Make sure all basic hood adjustments are good first.
