Living in Belgium, preparing my beauty for next season.
I'm working on my '74 2,0 with stock FI system. What else do you do in wintertime ?
I've just changed my distributor with a complete 1,2,3 ignition system. I want to get rid of those contact-points and have a good solid ignition system.
Does anyone has experience with this setup ?
Folowing the manual that comes with the ignition, I have to put the curve to "2" . This means that the max advance is 22° at 2700 rpm. This is what i did. If i tune-in the timing with my strobo, on the original timingmark, the engine is running; yes thats all to say. It's not Wauww... I think it runs even better when i put away the strobo and just use my ears to do the job.
Maybe another curve will be better ?
Any suggestions from you guys?
Kind regards,
