joeav8tor
Mar 18 2005, 11:57 PM
hi guys,
I would like to know the name of the CV joint tool, and the best place to get it...Sears, Lowes, Home depot, or an auto parts store...
thanks
joe
skline
Mar 19 2005, 12:00 AM
Its called a 3 square 8mm, I picked up a whole set of them for like $6.00 at the local FLAPS.
Lou W
Mar 19 2005, 12:39 AM
$17.00 on the Snap On truck.
mightyohm
Mar 19 2005, 12:43 AM
$1.99 at the local VW bug shop.
Gint
Mar 19 2005, 12:45 AM
8mm triple square. If you go to a non-bug shop, ask them for the bug cv joint tool, then look at the package and make sure it's 8mm.
redshift
Mar 19 2005, 12:48 AM
Do not be caught like poor Aaron, in a pinch, with nothing but visegrips..
The driver's inside coming off causes most damage! BAM! BAM! BAM! POW!
-metal skids in rearview-
M
ArtechnikA
Mar 19 2005, 06:06 AM
after you get the tool, make SURE the sucket in the head of the bolt is CLEAN (use a spray solvent like brake or carb cleaner and the little red straw but USE EYE PROTECTION because the sprayback WILL get you. then make sure whoever did this job last didn't replace any of the triple-square fasteners with Allen hex. it happens.
tap the tool gently but firmly into the bolt's socket before trying to twist it out.
you already have your new Schnorr washers, yes?
skline
Mar 19 2005, 07:39 AM
Joe, You may want to have new CV gaskets before you go pulling them off. Not a good idea to run without gaskets in there as it makes a nasty mess when it starts slinging CV grease underneath. They are cheap, I usually buy about 6 at a time when I buy them. Nice to have some laying around.
joeav8tor
Mar 19 2005, 09:49 AM
thanks everyone for your replies,
I will get the tool today...I ordered an upper and lower fuel line kit that includes injector elbows...got small and large FI seals, and intake runner boots, and CV gaskets coming...and cheese head screws...if time permits, I will take the engine tin off and either paint or powder coat it...if I can...I appreciate the advice
Jor
watsonrx13
Mar 19 2005, 10:00 AM
Picked mine up at NAPA for $8.95, last year....
