QUOTE(sean_v8_914 @ Jan 31 2016, 02:05 PM)
another consideration while you are in there is flywheel condition. a flywheel that has been cut will compromise the travel relationship of the throwout bearing fork.
before you remove the gearbox, make note of where the fork exits the hole in the gear box bell housing. a poorly cut flywheeel or one that has been re-surfaced multiple times will consume the avialable space for fork movement thru the exit hole.
a WASHER UNDER THE PIvot ball will help restore this relationship
Thanks everybody! I have a new flywheel, and noticed the surface plane for the clutch was about 1/8th in. different than the Chevy flywheel/ block that came out of the car. (new Honda going in). This showed up as soon as it was bolted together, with half the "window" being used just to contact the clutch fingers. I took it apart, bent the clutch fork for more travel, but didn't accomplish much, so checked the bushing. I have also added a second washer, so combined with the fresh bushing, hope to have it right. Again, thanks for the ideas!
