The fuel line replacement is an easy job. 1) Drop engine & tranny
2) Gut interior
2.5)Remove shifter plate & front and rear access panels
3) pull fuel tank etc.
4)Remove passenger rear wheel
5) Insert 1st fuel line, call out to helper "push" "pull" rotate clockwise 20 degrees,
no the other clockwise, no counterclockwise, not so hard, pull it back, it's snagged,
,easy now, where did it go?, I think I see it! How does this boot/grommet line up? We did it, not to bad!
5.5)Repeat step 5 for 2nd (return fuel line) you will need to add more time for additional snagging and questioning of your helpers skills, his basic grasp of the English lanquage and general competence. After you calm down and apologize to your helper this step really isn't that tough.
6) Reassemble reverse order of installation
