http://sfbay.craigslist.org/sby/pts/5426899600.html#
Porsche 914 2.0 dual port FI disributor - $500 (cupertino)
condition: excellent
make / manufacturer: Bosch
model name / number: 914 2.0 FI
Porshe 914 2.0 Dual Port Vacuum FI Distributor for sale. This Distributor is for a 914 2.0 FI only.
Here are the numbers on the distributor: JFUDRX 4 <------
0231 174 001
022 905 205F
Do your home work to see if this is the distributor for you. The distributor is in excellent condition with the exception of the Vacuum pot. Only one side of the pot is working. The pots are still available online.
This distributor has been completely torn down and completely cleaned, lubed , and reassembled. The centrifugal weights/springs and shaft area is free moving and working as it should. The trigger points have been cleaned and are working. The points plate has been cleaned and lubed and is free moving. The points plate ground strap is intact and in good condition. A new outside shaft O ring has been installed. A used Cap, Rotor, Point set, Condenser are installed. I did however clean them up and the dizzy will work as is but would recommend some new parts. A Pertronics pointless ignition kit would work great. These 914 2.0 FI distributors are getting very scares. Good ones even more so. The price is $500. Sold as is, Local pickup only, NO SHIPPING!
Please contact Gil at 408-813-9101, text is OK also. Thanks
