QUOTE(3d914 @ Feb 8 2016, 10:12 PM)
Cool, thanks. Lots of neat variations from stock. I like them! I noticed that all put something over the basic dash frame. I was thinking of just painting the frame body color and not putting anything over it.
Here's a pic of just the frame - the metal cover with vinyl is removed. This would be body color with nothing else added. The other thing I like about this is the face height will be the same across the dash - instead of the radio area being lower.
Thoughts?
You could cover the frame and make it look like this
, the double curve hump took me two attempts , the second I made a cardboard template wrapped it around trimmed it
then layed it flat , cut the sheet metal & then had a sheet metal ducting place roll it , the same for the face , I took the dash frame to them and had them brake bend the face cover then I attached it with removable screws so I could scribe the radio hole,the glovebox hole & steering column slot , removed it & opened the holes, Bill D.
Click to view attachmentClick to view attachmentClick to view attachment
