Looks better than my car!
Rick is right with the information above.
...but if you want to get it started....This is what I did to mine so I could at least check the engine compression and mechanical issues.
Change all the fluids, empty out the gas tank, change the fuel line, and add a new fuel filter, plugs and plug wires, points, rotor cap. Check your brakes all the way around, break lines, pads. Probably need new tires too.
I just kept my road test to short drives up and down my street and a short distance from home.
Do a lot of research and ask questions.
Good luck.
