I didn't get any pictures of it - the carnage wasn't easy to see since it's on the front side of the motor which is directly behind the driver's firewall. However I had several chunks of engine case laying on the floor of the chassis and saw the bottom of a rod sticking out through the hole. However it was typical for how these engines blow - they toss a rod out the front which of course is right next to the headers and oil covers the exhaust immediately, resulting in a fire. When we pull the motor I'll get some pictures.
This all stems from the last time the driver had the car out about 2 months ago. I was not with him but I had the car prepped in advance for him. He went out and won the first race, then the next day dropped a ton of oil. Of course, instead of shutting it down, he drove back around to the pits during which time he noticed OP was fluctuating
. We tracked it down to a 90 degree swivel which had failed, but the engine still had 3 quarts left in it. I of course recommended with a $5k motor that it should be taken apart and bearings inspected, or at least have the oil sent out and analyzed. However, driver decided to button it back up and race it as is. Made it through 4 laps of practice in the morning, then second lap of qualifying it let go. Lesson learned - motorcycle engines do not tolerate any ignorance or abuse
at all.
