QUOTE(screenguy914 @ Feb 17 2016, 05:21 PM)
- If an auxiliary add-on relay or Ford solenoid is under the chassis and not protected, that location invites more corrosion from road splash.
Sherwood
Have you
personally had a Ford solenoid fail due to corrosion?
Really? In So.cal?
I've installed literally hundreds of Ford solenoids and have had only one failure due to water/corrosion.
That failure was on my own daily driver (8 winters), 1971 VW Super Beetle, that had been driven for at least 5 hard Canadian winters, of salted to shit roads before the solenoid failed. It failed due to being rusted so bad it fell apart.
Please note by this time I was also replacing one foot square sections of the inner fenders, because the wife was complaining of getting slush in the face while driving.
It's the only single failure I"ve ever had, but to be fair IIRC there was a member reported failure last year due to a cheap china made solenoid.
I have replaced a few bosch relays over the years and I agree I did suspect moisture in them, but those relays are meant to be kept high and dry.
The other excuses you have about the Ford solenoid , Meh... whatever floats your boat, do as you like, not worth arguing.
But on this newest excuse of yours about corrosion, I'm calling total
Cheers
