The trigger will work, but the trigger wheel is no good. You can buy a flat wheel from ebay.
O2 sensor might not work, you need the same Bosch unit used on a WB O2 meter. Most meters have a ouput wire to connect to the EFI.
The dubshop stuff is cool, but spendy, if you are a DIY'er you can save a lot of coin.
BUT, the PM you sent me and this tells me you have not done anywhere near the research needed to be a successful DIY'er. I'd say you need at least a couple hundred hours of research. Then there's the build time and learning curve.
Like I said I'd do a single TB stock intake system first, before you try an ITB system.
If you plan to copy my motorbike ITB's two things, one is give the credit due and two you better be a pretty excellent custom fab guy.
If time is money or it's beyond your skills/tools it's better to just buy the stuff.
