QUOTE(db9146 @ Feb 21 2016, 05:34 PM)
If you are intending on using this tool on the Turbo Tie Rod ends from a 930 or such, the tool I purchased as part of the GB here did not fit....it was too shallow. Maybe it was just mine....
The top and bottom tabs need to extend out further from the handle. Imagine the "round" shape that would fit the tool as it is and you'll see what I mean.
Mine tool worked on the turbo tie rods but I had to file the center and one of the side tabs a little bit to get it to seat down correctly. I believe I filed the side of the tabs not the tops.
Jeff B
