chunger
Mar 21 2005, 09:49 PM
Hello,
I was wondering if it's possible to mud over MDF. . . I have a couple of wall panels that are MDF faced, and I'm wondering if I can mud and tape the corners that abutt sheetrock with normal drywall compound.
-'Chung
Trekkor
Mar 21 2005, 09:51 PM
You might try a stucco bonderizer to seal it first.
KT
bondo
Mar 21 2005, 09:57 PM
Keep in mind that the real reason for sheetrock is fire resistance. Depending on the situation, the MDF may keep it from being up to code.
Regular tape and mud would probably work, but I've never tried it. Use the setting type mud, it's stronger than the premixed stuff.
riverman
Mar 21 2005, 10:01 PM
Regular drywall compound might not bond to the MDF the same because the porosity is not the same. You might have to glue your cornerbead down to keep it in place.
Never tried it, so don't know for sure.
scruz914
Mar 21 2005, 10:31 PM
I have never textured over MDF. I have textured over plywood and solid pine. No problems with the compound or tape. You might want to sand the MDF with 80 grit to give the surface some tooth. I would also make sure that the MDF is solidly attached to the studs or whatever it is covering. Use drywall screws. You will have to drill pilot holes and counter sink. The screws will never bury into the MDF and will break if you try without counter sinking.
-Jeff
chunger
Mar 21 2005, 10:35 PM
I'll give it a shot. I have a test piece drying right now to see if it holds up, but if it works on pine, it should be ok w/ MDF.
As for fire code, there is 5/8" drywall underneath the MDF.
-'Chung
Bleyseng
Mar 21 2005, 11:46 PM
Prime the MDF first and then it will work. BTDT
rhodyguy
Mar 22 2005, 08:03 AM
like geoff said. use plastic corner bead and use the spray adhesive to hold it on. you might scuff the mdf a bit first.
k
URY914
Mar 22 2005, 09:49 AM
If you are taping to the MDF and the SR you'll have a crack in the mud for sure. Two different materials= cracks.
You need to seperate the materials not try to connect them with mud and tape.
