I have a set of exhaust manifolds with the heat exchanging jackets on them. see attached
The heat jackets have no holes but they are loose, they slide forward and backwards on the inner pipes. And a portion of the pipe where it exits the jacket close to the flange that mounts on the muffler is pitted badly. I also have a set of new exhaust manifolds/Pipes that are "Naked" (no Heat jackets)
Wondering if I could carefully take the heat jacket's off the pitted up pair and install them on the new "Naked" pipes. Effectively making a new set of heat exchanger pipes
Click to view attachmentClick to view attachment
The new set I want to install the Heat jackets on
Any help, advise or past experiences with these would be most appreciated.
Thank you
