QUOTE(DCJosh @ Feb 23 2016, 07:42 PM)
Anyone from Minnesota who has posted, have you seen the car in person as well?
Were any of you looking to buy it? Did anything turn you away?
In any case, I'm going up to see it this weekend and pull the injectors so that I can service them and put it on some jack stands while I put some new tires on so I can roll it out of the barn. I'll bring a screwdriver and a better camera and really take a look at the longs then.
Hoping for the best but preparing for the worst. I have seen other cars in the build threads which started off in much worse condition, so my fingers are crossed at least.
DC Josh
Hey Josh, from one Newbie to another I looked at it twice, months ago....It was very difficult to look at because of all the cars packed around it and the lighting, that's why I went back the second time.
The second time I brought a spotlight and looked at everything much closer than the first time. My observations were the car had been painted before, with the Jambs and inside both the trunks being original. Really liked the color though. While laying on my back on the dirt floor looking at the front suspension it appears that something with the torsion bars or struts is messed up, the front has no spring or rebound in it and the front beam is only about 2 inches off the floor.
Progressing towards the back of the car, the Longs under the rocker panels were in various stages of solid to rotten, some of the jack points (Doughnuts) were there and some were not. Arriving at the back it seemed about the same as the rest of the car, some solid some holes, the exhaust was loose and was tied up by wire of some sort.
The Interior, Seats were the smooth(Not the Basket weave) vinyl, sort of cracked when they were sat on. Pedal cluster felt loose not mechanically, rather mounting wise. The pressure plate may be stuck to the flywheel, or something else causing the pedal to feel like it did.
The CL pictures that were taken outside show the car to have uniform gaps between the doors, fenders (Except where the front right fender was hit) and hoods. But looking at it closer in the barn that Uniformity had gone away, especially from doors to fenders. It had a "droop" most noticeably on the passenger side, but the driver side also had some as well.
With the inability to actually put a battery in the car and "Juice" things up, and the info shared above I was reluctant to make an offer and went on to other things.
Hope this helps, by the way did I say how much I liked the color.
Good luck and keep us informed!
