Soe anyone have a decent handle on the proper size or specification for the original 914GT hood pin plates' rivet? Or maybe a good close-up shot to measure the relationship between the width of the four plates and the head of the rivet???
Thanks
ConeDodger
Feb 23 2016, 11:29 AM
I'd guess they were whatever Hans had in the toolbox... Franz, in the next bay over from Hans took less time to think about the rivets than it took you to type your question.
With rivet selection grip range is probably the most important.....too long a grip range and you are f'd as the rivet will come loose over time if it is a pop rivet.
I.d select a number 6 rivet with a grip range just within the metal thickness to be fastened.
Rivet material is a matter of choice...if it were I alum or stainless....
914_teener
Feb 23 2016, 12:02 PM
....also Forrest.....use a compound pop rivet gun or air pop gun to pull a No 6 rivet.
Larmo63
Feb 23 2016, 02:30 PM
There is more information on what you are asking here:
