I've had some rear tie down eyelets lasercut at work and they will go onto the the rear lower shock bolt. I cant get the bolt out because the heat exchanger is in the way. Does anyone know if the bolt will clear the HE's if I loosen the top shock nut?
I'd rather not pull the HE's out again if I dont absolutely have too...
