914forme
Feb 28 2016, 02:48 PM
FS: Troutman Brake Bias Valve [s]$50$25, plus shipping Should go flat rate in a small box in the CONUS.[/s]Sold, Thank you!!!!
Click to view attachmentClick to view attachmentThis is the female bolt that secures it to the stock proportions valve bracket in the engine compartment. The upper hole , just slides over the other stud.
Click to view attachmentThank you,
Stephen
914forme
Mar 1 2016, 10:52 AM
Bump for price drop
914forme
Mar 13 2016, 07:51 PM
Bump for Price drop
bahnzai
Mar 14 2016, 07:04 AM
Stephen,
I'll take it. PM me how the narendra funds.
Thanks,
Danny
bahnzai
Mar 14 2016, 07:06 AM
"How to send funds"
gotta love auto correct
GregAmy
Mar 14 2016, 08:30 AM
For future reference, what is it and how does it compare to the stock one?
(I know what a brake bias valve is, referring to the Troutman" part...)
914forme
Mar 15 2016, 02:21 AM
QUOTE(GregAmy @ Mar 14 2016, 10:30 AM)
Troutman made the kit back in the day, so they where the manufacturer of the unit.
ChrisFoley
Mar 15 2016, 06:49 AM
QUOTE(914forme @ Mar 15 2016, 04:21 AM)
I doubt Troutman actually made the bias valve.
I have one of those in my used parts collection somewhere.
GregAmy
Mar 15 2016, 10:20 AM
Ok, is it "better" than the stock one? If so, in what way?
914forme
Mar 15 2016, 12:53 PM
Better than the stock one, for a couple of reasons. If you have messed with stock brakes, and swapped in a 320i front caliper, or a 911M caliper minus the spacers, or any other caliper combination, you can adjust the bias to give you the desired pressures before lockup. I also found it easier to bleed than the stock setup, that could just be a perception. Kind of like the butt dyno.
I was running 87 carrera front and rears, might still, though Wilwoods are calling me to reduce unsprung weight.
Jeff Hail
Mar 15 2016, 11:36 PM
Its a Kelsey Hayes part and still available new. Its used for muscle car brake conversions when dumping front drums and switching to discs. Adjustment is 100-1000 psi.
I've seen these installed on early Mustangs. Seems the original oem "Velvet Touch" brake shoes were a little too velvety so folks installed the valve to stop that pesky lock up.
Good price it sold for. About 1/3 or the new part cost. Somebody got a good deal!!!
GregAmy
Mar 16 2016, 06:11 AM
Good info, thanks. Prior owner installed BMW calipers, and I am experiencing front lockup on aggressive braking.
Anyone know the K-H part number?
